I would like a textbox to show nothing if the value coming from the database is NULL.
Currently, it is a number so it shows '0'. If the value is '0', I would like it to show nothing.
Using the GetValueJavaScript attribute, can you write add an if statement to the this attribute?
Thanks.
The classic controls are retired and no longer supported. They are also not included in NetAdvantage versions 11.2 and above. I would suggest you to migrate to the new controls based on our Aikido framework. Here you can find more information on the matter:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2013.1/CLR4.0/html/Classic_Control_Migration_Guide.html
http://ko.infragistics.com/community/blogs/taz_abdeali/archive/2010/03/04/asp-net-product-changes.aspx
I tried copying your code to my application and I still get the same error...ReferenceError: undefined.
Thanks for your reply.
Unfortunately, I cannot run your application. You are using a later version of the webdatagrid. I am using v11.2. Your version is v14.2.
Is the ability to set the javascript something that was added to a later version of the datagrid and not available in v11.2?
The only other difference I see is that my control is a textbox and your controls are either Date fields, currency or integer fields.
Gloria
I have created a sample for you in order to show you my approach. I hope you will benefit from it. If the issue still persist, could you please make the necessary changes in order to reproduce it into the sample and return it back to me.
Thanks for replying.
When I use your code, I get an error "Reference Error: Undefined".
This is my code:
<ig:RowEditingClientBinding ColumnKey="Lat" ControlID="txtLatEdit" GetValueJavaScript="$get({ClientID}).value" SetValueJavaScript="$get({ClientID}).value={value} == null ? '' : {value}" />
