I'm using 15.1, and I can't get the HTML editor to display. The HTML editor DLL is a reference for the page (Infragistics4.WebUI.WebHtmlEditor, version 15.1.20151.1018).When my test page loads, I get the following error (stack trace is below):Index (zero based) must be greater than or equal to zero and less than the size of the argument list.This error occurs with all browsers that I tested: Internet Explorer, Firefox, and Chrome.Does anyone have any idea what the issue might be?CharlesDetails:To isolate the issue, I created a test page with the following:<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head></head><body><h1>TEST test TEST</h1><ighedit:WebHtmlEditor ID="WebHtmlEditor1" runat="server"></ighedit:WebHtmlEditor></body>Stack Trace:[FormatException: Index (zero based) must be greater than or equal to zero and less than the size of the argument list.] System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String format, Object[] args) +11118244 System.String.Format(IFormatProvider provider, String format, Object[] args) +63 Infragistics.WebUI.WebHtmlEditor.WebHtmlEditor.RenderEndTag(HtmlTextWriter writer) +3334 System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +43 Infragistics.WebUI.WebHtmlEditor.WebHtmlEditor.Render(HtmlTextWriter writerForIE) +626 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +57 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +128 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Page.Render(HtmlTextWriter writer) +29 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +57 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1386
Never mind. I found the correct service release. On to a different error :)
I'm having the same issue. Is there a fix for this yet?
Matt
Thank you for your feedback!
Actually it appears to be a known issue and a fix has already being created. It will be made public in the upcoming Service Release, scheduled for June 12 as per the following calendar: http://ko.infragistics.com/support/service-releases
Please let me know if you have any questions regarding this.
