370
Get Row data in ItemCommand event
My webdatagrid has a column of links.  When the user clicks the link an ItemCommand event is fired.  Within that event I would like to retrieve the data from the other bound columns. This is my markup:
 <ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server"
    Height="600px" Width="875px"
    Key="SqlDataSource1_DefaultView" DataMember="SqlDataSource1_DefaultView"
    DataSourceID="WebHierarchicalDataSource1" AutoGenerateBands="False"
    AutoGenerateColumns="False" StyleSetName="Windows7" DataKeyFields="DrNum"
    onitemcommand="WebHierarchicalDataGrid1_ItemCommand"
    oninitializerow="WebHierarchicalDataGrid1_InitializeRow">
    <Columns>
        <ig:BoundDataField DataFieldName="ID" Key="ID" Hidden="true">
            <Header Text="ID" />
        </ig:BoundDataField>
        <ig:BoundDataField DataFieldName="DrNum" Key="DrNum" Hidden="true">
            <Header Text="DrNum" />
        <ig:TemplateDataField Key="LastName">
            <Header Text="Last Name" />
            <ItemTemplate>
                <asp:LinkButton ID="LinkButton1" runat="server"
                    Text='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem,"LastName") %>'
                    CommandName="GetInfo" CommandArgument='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem,"ID") %>' />
            </ItemTemplate>
        </ig:TemplateDataField>
        <ig:bounddatafield datafieldname="FirstName" key="FirstName">
            <header text="First name" />
        </ig:bounddatafield>
        <ig:BoundDataField DataFieldName="MiddleName" Key="MiddleName">
            <Header Text="M. Name" />
    </Columns>
</ig:WebHierarchicalDataGrid>
This is my ItemCommand Event:
protected void WebHierarchicalDataGrid1_ItemCommand(object sender, Infragistics.Web.UI.GridControls.HandleCommandEventArgs e)
    if (e.CommandName == "GetInfo")
        string ID = e.CommandArgument.ToString();
        Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid grid = (Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid)sender;
        //HOW DO I GET THE VALUES OF THE COLUMNS BELOW?
      string tstrFullName = grid.Columns["FirstName"].ToString() + " " + grid.Columns["MiddleName"].ToString() + " " + grid.Columns["LastName"].ToString();
The event is triggered and the e.CommandArgument is the ID of the row.
I need to get the values of the other columns.  How do I do that?
THanks.
