Hi guys,
Our company are using for now IE8 but next month they will convert all our machines to IE11.
In my applications I am using Infragistics 11.1 version and I try to run against IE11 and did not work correctly.
Could you tell me is there any other Infragistics version compatible with IE11 without changing any controls.Also if there none, what should I code in my Application to be compatible with IE11.
thank you.
Hello Jane,
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Thank you for contacting Infragistics Developer Support!
Please note that the version you are using is retired several years ago and understandably would not work with modern browsers that were released after the last volume of the classic controls, which was Infragistics NetAdvantage v11.1 of ASP.NET. The product lifecycle is stated in the following page:http://ko.infragistics.com/help/product-lifecycle.The only possible solution in this case is to use a product that is supported under newer browsers, which you can identify in the supported environments page at:http://ko.infragistics.com/support/supported-environments.So what you could do is to upgrade to the new ASP.NET Ajax tool-set. You can take a look at it at:http://ko.infragistics.com/products/aspnet.
