please see the attached to compare images using WebPanel (first image) and now WebExplorerBar (second image) :
Here is coding using WebPanel:
<div id="ScrollArea" runat="server"><igmisc:WebPanel ID="ViewPanel" runat="server" CssClass="viewPanel" StyleSetName="Header"Width="805px" Height="870px"><ClientSideEvents ExpandedStateChanging="CancelXpand" /><Template><div class="content" id="content"><div id="navigation" class="navigation" style="height: 5px;"></div><div id="findemp" class="findemp" style="margin-top: 0px"><div id="personInfo" style="margin-top: 0px"><table><tr><td><uc1:CFNList ID="CFNList1" runat="server"></uc1:CFNList></td><%--<td>Location:<br /><asp:TextBox ID="txtLocation" runat="server" CssClass="txtinput" Font-Size="X-Small"Height="12px" Width="75px" MaxLength="6" ToolTip="Please Enter Six Char DBN (Dist, Boro, School"></asp:TextBox></td>--%><td>EIS ID:<br /><asp:TextBox ID="txtEISid" runat="server" CssClass="txtinput" Font-Size="X-Small"Height="12px" Width="75px" MaxLength="7" ToolTip="Please Enter EIS ID."></asp:TextBox></td><td>Status :<br /><asp:DropDownList ID="ddlStatus" runat="server" Width="125" CssClass="txtinput" Font-Names="Verdana"Font-Size="X-Small"><asp:ListItem Text="All" Value="W"></asp:ListItem><asp:ListItem Text="Pending" Value="P"></asp:ListItem><asp:ListItem Text="Approved" Value="A"></asp:ListItem><asp:ListItem Text="Rejected" Value="R"></asp:ListItem><asp:ListItem Text="Saved" Value="S"></asp:ListItem></asp:DropDownList></td><td><br /><asp:Button ID="btnSearch" runat="server" OnClientClick ="BLOCKED SCRIPT return ValidateData();" CssClass="selectitem" Text="Search" OnClick="btnSearch_Click" /></td></tr><tr><td colspan="6"><%--<asp:Label ID="lblError" runat ="server" Text ="Error Message" >Test Message</asp:Label>--%></td></tr><tr><td class="tbtxtbox" colspan="3" style="height:30px;"><asp:Label ID="lblError" runat="server" Height="10px" Font-Size="Small" ForeColor="red" ></asp:Label></td> </tr></table></div></div>
Here is coding using WebExplorerBar .aspx:
<ig:WebExplorerBar ID="WebExplorerBar1" runat="server" CssClass="viewPanel" StyleSetName="Header" Width="805px" Height="870px" > <Groups><ig:ExplorerBarGroup Expanded="true" ><Items><ig:ExplorerBarItem TemplateId="viewPanel"> </ig:ExplorerBarItem></Items></ig:ExplorerBarGroup></Groups> <Templates> <ig:ItemTemplate ID="ItemTemplate1" TemplateID="viewPanel" runat="server" ><Template><div class="content" id="content"><div id="navigation" class="navigation" style="height: 5px;"></div><div id="findemp" class="findemp" style="margin-top: 0px"><div id="personInfo" style="margin-top: 0px"><table><tr><td><uc1:CFNList ID="CFNList1" runat="server" ></uc1:CFNList></td><td>EIS ID:<br /><asp:TextBox ID="txtEISid" runat="server" CssClass="txtinput" Font-Size="X-Small"Height="12px" Width="75px" MaxLength="7" ToolTip="Please Enter EIS ID."></asp:TextBox></td><td>Status :<br /><asp:DropDownList ID="ddlStatus" runat="server" Width="125" CssClass="txtinput" Font-Names="Verdana"Font-Size="X-Small"><asp:ListItem Text="All" Value="W"></asp:ListItem><asp:ListItem Text="Pending" Value="P"></asp:ListItem><asp:ListItem Text="Approved" Value="A"></asp:ListItem><asp:ListItem Text="Rejected" Value="R"></asp:ListItem><asp:ListItem Text="Saved" Value="S"></asp:ListItem></asp:DropDownList></td><td><br /><asp:Button ID="btnSearch" runat="server" CssClass="selectitem" Text="Search" /></td></tr><tr><td colspan="6"></td></tr><tr><td class="tbtxtbox" colspan="3" style="height:30px;"><asp:Label ID="lblError" runat="server" Height="10px" Font-Size="Small" ForeColor="red" ></asp:Label></td> </tr></table></div>
We cannot achieve the same look.Please help me to resolve this issue.
Thanks so much
Hello Jane,
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Please provide a sample project replicating your issue so I can inspect it and debug it.
hi,
thanks for respond.I use the same StyleSetName and the same link:
link href="Styles/style_main.css" rel="stylesheet" type="text/css"
But image is not appearing on the screen.I dont know why.
As I able to see the references to Images are not correct and that is the reason why the both websites are different. Please check the references and set the correct ones.
If you are unable to resolve the issue please provide a working sample demonstrating it.
