630
Bug when clicking in two RowAdding line (green lines) then typing: after 1 digit, write same digit in the other line
I'm using WebHierarchicalDataGrid with 2 levels and RowAdding behaviors. When I click in the first column of the RowAdding line of the parent level (green line used to add a line), then I click the first column of the RowAdding line of the child level (green line to add a line), then I start to type the 3 digit number I want to enter, it writes the first digit in the last clicked cell then switch back to the parent's RowAdding line and type the same digit in the first column then continue to add the digits I type after. If I do exactly the same things but by inverting the lines, it works perfectly. I mean, if i click first column of the child RowAdding line, then the first column of the parent's RowAdding line then start to type the 3-digit number I want to enter, it works. Seems a bug in the Infragistics control. Is it fixed yet?
I've joined an example that causes the bug. It causes also the bug I mention in the thread "error rendering the control, object reference not set - with RowAdding without child row header"  http://ko.infragistics.com/community/forums/p/95415/471490.aspx#471490
I'm using Infragistics 14.1 with Visual Studio 2013
RenderErr_RowAddClic2.zip
