I need to edit all of my childRow in my WebHierarchicalDataGrid.
I do exactly the same as in the link (http://ko.infragistics.com/samples/aspnet/hierarchical-data-grid/editing-child-bands).
But the only one of my childRow is editable... Is what i forgot to do something ??
Hi Salvatore,
I'm glad that I could help.
Hello Daniel,
I managed to solve my problem
Thank you
Best Regards
Hello Salvatore,
Yes it is possible, although you should use WebHierarchicalDataSource and define all related DataView's, DataRelations, Members etc.
I will send you a sample that is using WebHierarchicalDataSource, I hope you will benefit from it, and will help you to achieve your requirements.
Is there a way to create a WebHierarchicalDataGrid from code behind using sqlDataSource, dataView, dataRelation...??
Everything i've find on the net does not work...
Hey Daniel,
You Can find my projet on file attached.
I don't understand the problems... It is a bug with the component ??
Thank
