I have one of my column as amount, i need that to be custom formatted. The format should look like "#,###0.00" Tried this below code, but in the UI i see #,###0.00 in place of numbers.
protected string Format(ControlDataField field, object value) { return "#,###0.00"; } protected override void OnInit(EventArgs e) { ExposureDetailsGrid.Load += (grid, arg) => { ((WebDataGrid)grid).Columns[5].FormatFieldMethod = (field, value) => { return PRISMConstants.AmountFormat; }; }; }
Please help me!!
Thank you for the update. With the FormatFieldMethod you have to actually format the value yourself then return it. Whatever value you return will be the value that displays:
http://ko.infragistics.com/community/forums/t/19758.aspx
If you want to apply a format string without formatting yourself I recommend use the DataFormatString property of the column. You can set it something like this:
<ig:BoundDataField Key="Department" DataFieldName="Department" DataFormatString="{0:N2}"> <Header Text="Department" /> </ig:BoundDataField>
That will format the column to be a number with comma separators for the thousands place and two decimal points. You can see the following link for other formats you can apply:
https://msdn.microsoft.com/en-us/library/dwhawy9k(v=vs.110).aspx
https://msdn.microsoft.com/en-us/library/az4se3k1(v=vs.110).aspx
I am also attaching a sample (note I have removed the ig_res folder). Please let me know if you have any further questions concerning this matter.
This is the code i tried
protected override void OnInit(EventArgs e) { ExposureDetailsGrid.Load += (grid, arg) => { ((WebDataGrid)grid).Columns[ExposureDetailsGrid.Columns.IndexOf(ExposureDetailsGrid.Columns.FromKey("EXPO_AUTH_AMT"))].FormatFieldMethod = (field, value) => { return "#,###0.00"; }; }; }
