Hi.
I am using Webtab 2011v2. For two months my web page with Webtab and WebDataGrid does nothing and does not working. Before two months the same page was working perfectly. Are 2015 version browsers after now not compatible with Infragistics controls 2011v2? What can I do?
Thank you for your question! Yes, there are a lot of changes from 11.2 to 15.2.
Have a look at NetAdvantage for ASP.NET Product Changes to see some of the major changes that was made.http://ko.infragistics.com/community/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx In order to help you make a smooth transition Infragistics is making the NetAdvantage for ASP.NET Grid Cheat Sheet available for your reference:http://dl.infragistics.com/pg/cheat-sheet/InfragisticsNAforASPNETGridCheatSheet.pdf The goal of the cheat sheet is to provide quick-access guidance to the myriad of features found in both the WebDataGrid and WebHierarchicalDataGrid. The cheat sheet is a step-by-step guide to using the features and behaviors of the NetAdvantage for ASP.NET AJAX grid controls. Steps and code for both grids is listed side-by-side for easy comparison among the controls. Please let me know if you have further questions about this.
