I have an Action in my controller, I am trying to offer the user the created excel file after it is created. there is either something wrong with the mimetype or How I am setting up the workbook, I saw there were save options for workbook.save() but didn't know which options I needed to set to get this to work, if any. Thanks in advance!
public ActionResult RentRollExcel(int id) { var property = _db.Properties.Find(id);
var workBook = new Workbook(WorkbookFormat.Excel2007Template); var fileName = property.Name + "-RentRoll"; workBook.Worksheets.Add(fileName); var stream = new MemoryStream(); workBook.Save(stream); return File(stream, "application/vnd.openxmlformats-officedocument.spreadsheetml.sheet"); }
Hello Landrum,
Since you are creating Excel Template the Mime type should be also for template.
You can say stream.ToArray() in order to write ti to result.
1 2 3 4 5 6 7 8 9 10 11 12 13
public ActionResult RentRollExcel(int id) { var property = _db.Properties.Find(id); var workBook = new Workbook(WorkbookFormat.Excel2007Template); var fileName = property.Name + "-RentRoll"; workBook.Worksheets.Add(fileName); var stream = new MemoryStream(); workBook.Save(stream); return File(stream.ToArray(), "application/vnd.openxmlformats-officedocument.spreadsheetml.template"); }
Let me know if you need further assistance.
