The column widths of the WebDataGrid may be autosized based on header and cell text width.
In order to autosize column width, the Initialize client side event of the WebDataGrid has to be handled. We can iterate through the columns and check whether the header text is wider than the current width of a column. Below is some sample javascript code of how this can be done.
function _dg_Grid_Initialize(sender, eventArgs) {
if (null == $find(sender.get_id())) { return; }
var textWidthChecker = document.getElementById('textWidthChecker');
var grid = $find(sender.get_id());
var columns = grid.get_columns();
var row = grid.get_rows().get_row(0);
for (colIdx = 0; colIdx < columns.get_length(); colIdx++) {
var col = columns.get_column(colIdx);
textWidthChecker.innerHTML = col.get_headerText();
var cellElement = row.get_cell(colIdx)._element;
if (!col.get_hidden()) {
// resize based on cell content widths
if (textWidthChecker.offsetWidth > cellElement.offsetWidth) {
col.set_width(textWidthChecker.offsetWidth);
// resize based on header text length
if (col.get_headerElement().offsetWidth < col.get_headerText().length * 8) {
var newWidth = (col.get_headerText().length * 8).toString() + 'px';
col.set_width(newWidth);
Similarly, we can also check whether the value of some row cell is too wide to be displayed:
