Request you to please advise the best approach to upgrade Infragistics ASP.NET from ver 9.0 to 11.0
Thanking you in anticipation
In Step 3)Replace all old assemblies in the Bin folder with the new
where do I get the latest 11.1 assemblies.
Hi Maya,
Thank you for your kind support.
Have a nice day.
Hello Teller ,
You can try using the upgrade utility to upgrade your application: http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_Using_Version_Upgrade_Utility.html
If you cannot upgrade your project using Version Upgrade Utility you can upgrade your project manually by following these steps:
1. Get a copy of your project that you have not modified with Version Utility
2. Make a backup copy of your project
3. Replace all old assemblies in the Bin folder with the new
4. Open your project with Visual Studio and press Ctrl+H (Quick Replace)
Enter the following Values:
Find what: .v9.x Version=9.x.200xx.xxxx This should be your current version of ver.9.x , you will need to change it.
Replace with: .v11.1, Version=11.1.20111.2238 (This is the current version)
Look in: Entire Solution Select Entire Solutions to change all existing references in your project
Click on the “Replace All” button
Please note that it is very important to enter the exact versions
5. Create a new empty project or website and drag any control from ver 11.1. A new ig_res folder will be generated in the project. Copy this folder to your project if there is such folder then overwrite it.
6. Remove licenses.licx and App_Licenses.dll the should be located in:
C:\...\YourPoject:\licenses.licx
C:\...\YourPoject:\Bin\App_licenses.dll
7. Clean and rebuild your project.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
