1935
Appropriate place to set column width
Where is the best place to set the width of cells in columns of the gridview.
Would it be here in the cell creation method...
-(IGGridViewCell *)gridView:(IGGridView *)gridView cellAt:(IGCellPath *)path
*** EDIT ***
Actually, I just reviewed the documentation, it looks like it's supposed to be here
- (IGColumnWidth *)gridView:(IGGridView *)gridView widthForColumnAtIndex:(NSInteger)column
  • 40030
    Verified Answer
    Hi David
    Yup you got it
    if every column will be the same width you can also just set the column width property on the grid
    or if you use the IGGridViewDataSourceHelper classes you can create columns and specify the width of each column there
    -SteveZ
