5020
Most Performant Chart Configuration with These Realm Objects
I need advice on the most performant setup for a IGChartView with a line series. It's really basic, but I'm second guessing the previous designs that I've used because maybe something new has been released in the interim. Here are my realm objects:
class RecordingRow: Object {
    dynamic var createdOn:NSDate = NSDate()
    let measurements = List<Measurement>()
class Measurement: Object {
    dynamic var value:Double?
Measurement order is guaranteed. Time interval between measurements is also static. However, measurement values are optional and should be displayed differently on the chart (i.e. not a straight line between the last known value and the next valid value). My goal is to chart one "column" of this data. I must avoid calculating timestamp strings as much as possible because they are expensive, so those should be dynamic (delegate?).
Specifically:
• Do I create a DataSourceHelper and package up my data in Arrays?
• Is there an easy delegate pattern to use here?
