125
Documention
Again Hi all,
Thanks for kind and fast sport.
I want to draw financal indactors below of my main chart. But because of the yAxis labels lengths charts doesnt start from same point. How can i get the main chart y axis margin and give same value to below chart. I must be sure both charts x axis must show same time frames at same points
  • 26458
    Verified Answer
    The best way to do this is to set an extent on the y axis for both charts.
    IGNumericYAxis *topYAxis = (IGNumericYAxis*)[topChart findAxisByKey:@"yAxis"];
    IGNumericYAxis *bottomYAxis = (IGNumericYAxis*)[bottomChart findAxisByKey: @"yAxis"];
    topYAxis.extent = bottomYAxis.extent = 50;
    This should ensure that both vertical label panels have the same width and the chart viewports start from the same x coordinate. Try different extent values to get a better fit.
