According to "Reveal" version 6, I have over 100 tabs in memory, each with a different memory address, even though I've only defined the tab to have a single, centered tab.
I think you guys have a bad leak in the slide tab view.
A few replies ago I had included a sample project. If you want, give it a try and maybe modify it to see if you're getting the same issue.
Hmmm... ok.
Well maybe I'm using it wrong, but I'm not adding tabs more than once.
I set a breakpoint at the place in code where I set up the tab, and it's never hit more than the initial first time.
Really odd
I ran the sample through the Instruments Leaks tool and didn't see anything extra being added after 30 seconds of opening and closing tabs.
I'll try and get to a sample project this weekend.
It appears that each time I slide open and close my single, centered tab, a new tab is added in memory (though not visually).
Without more information about how you're using the control it's hard to understand what could be creating extra views. I created a quick sample to take a look and didn't notice anything off.
(Link)
Attached to this reply is the sample project. If possible, could you update the sample to help reproduce your issue?
