Hi, I added IGChart.Unified.dll file to my xamarin iOS native project references , it is working in simulator but when I running into device I am getting errors. I am attaching the log please check it and tell me procedure how to fix it.
I attached Screenshots related please check it.
Today I tested the static library that is used inside of the DLL assembly and it contains all the necessary architectures. Afterwards, I set the Linker options to Don't Link and I was able to deploy to the device. Using this option ensures that no assemblies are modified. Give this a try and let me know if that solves your issue.
One of our developers was able to reproduce the issue with similar errors. On Monday I will investigate using their machine to see what can be done. Thank you for your patience.
Not yet, can you please check if you have latest IGChart.Unified file we have 2017 version may be version problem we are facing if you having latest IGChart.Unified.dll file .can you check .
Thank you. To update you on what's going on behind the scenes, I'm getting others in the company to test the project to see if your issue can be reproduced. Has there been any new updates on your end?
We are using "NUCLiOS 2017 Volume 1" for our development currently. Is there any known issue in this version? Please advise. Thank you!
