Hi all !
I can't pass this stage
sh-3.2# sudo /usr/sbin/installer -pkg /Users/trio-soft/Downloads/Infragistics_NucliOS_2012.pkg -target /Cannot install on volume / because it is disabled.installer: An error occurred while evaluating JavaScript for the package.
Can anyone help ?
Thanks in advance !
I sent you (via e-mail) a link for new download. I hope that work for you.
It is trial version.
Mac Version = OS X Lion 10.7.5
Hi Abdullah
Are you running the trial or licensed install? What is the version of your Mac OS?
Hi Ammar
I am trying to install trial version and getting the error below. NOT TRUSTED.
Xcode Version = 4.6.3
-- Begin install -----Oct 2 10:22:28 xxx <Error>: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=102 "The package “infra.pkg” is untrusted." UserInfo=0x7fe885043fa0 {NSLocalizedDescription=The package “infra.pkg” is untrusted., NSURL=file://localhost/Users/xxx/Documents/Docs/infra.pkg#framework.pkg, PKInstallPackageIdentifier=com.infragistics.NUCLiOS.framework.13.1.pkg, NSUnderlyingError=0x7fe88502f8a0 "The operation couldn’t be completed. CSSMERR_TP_NOT_TRUSTED"} { NSLocalizedDescription = "The package \U201cinfra.pkg\U201d is untrusted."; NSURL = "file://localhost/Users/xxx/Documents/Docs/infra.pkg#framework.pkg"; NSUnderlyingError = "Error Domain=NSOSStatusErrorDomain Code=-2147409622 \"The operation couldn\U2019t be completed. CSSMERR_TP_NOT_TRUSTED\" UserInfo=0x7fe88502be80 {SecTrustResult=5, PKTrustLevel=PKTrustLevelNotTrusted, NSLocalizedFailureReason=CSSMERR_TP_NOT_TRUSTED}"; PKInstallPackageIdentifier = "com.infragistics.NUCLiOS.framework.13.1.pkg"; }Oct 2 10:22:29 xxx<Error>: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Hi Avi,
I made some changes to the install and I think it should work for you now. please download and install the new build located here:
Trial: http://download.infragistics.com/users/ammarz/ios/Infragistics_NucliOS_2012_Trial.pkg.zip
License: http://download.infragistics.com/users/ammarz/ios/Infragistics_NucliOS_2012.pkg.zip
Let me know your result
