65
Custom header cell with background image or gradient
I'ts me again ;) I like this grid component...it's great to work with.
Are there any samples how to customize the header cells regarding to the appearance? I'd like to have a gradient - realised with flexible background image or painting a gradient layer.
I tried something like:
    public class GridHeaderCell : IGGridViewHeaderCell
        public GridHeaderCell(string identifier) : base(identifier)
            Initialize();
        public GridHeaderCell(IntPtr handle) : base(handle)
            Initialize();
        private void Initialize()
            var gradient = new CAGradientLayer();
            gradient.Frame = Bounds;
            gradient.CornerRadius = 3.0f;
            gradient.MasksToBounds = true;
            gradient.StartPoint = new PointF(0.5f, 0.5f);
            gradient.EndPoint = new PointF(1.0f, 1.0f);
            gradient.Colors = new[] { UIColor.FromRGB(50, 0, 0).CGColor, UIColor.FromRGB(200, 0, 0).CGColor };
            Layer.InsertSublayer(gradient, 0);
But the header is still black. Creating a custom theme allows only to set simple background colors...
Cheers, Danny
  • 40030
    Verified Answer
    Hi Danny!
    I'm really glad to hear you're enjoying the IGGridView.
    Basically the CAGradientLayer doesn't autosize, so you need to keep it's frame up to date. When you initially set it up, there is no frame on the HeaderCell, so the gradient layer you're creating is 0,0.
    All IGGridViewCell's actually expose a method to override called SetupSize. Simply override that method, and whenever the cell's size changes, this method will be called and you can update your gradient layer's frame:
            CAGradientLayer _gradLayer;
                Initialize();
                Initialize();
                _gradLayer = new CAGradientLayer();
                _gradLayer.CornerRadius = 3.0f;
                _gradLayer.MasksToBounds = true;
                _gradLayer.StartPoint = new PointF(0.5f, 0.5f);
                _gradLayer.EndPoint = new PointF(1.0f, 1.0f);
                _gradLayer.Colors = new[] { UIColor.FromRGB(50, 0, 0).CGColor, UIColor.FromRGB(200, 0, 0).CGColor };
                Layer.InsertSublayer(_gradLayer, 0);
            public override void SetupSize (SizeF size)
                base.SetupSize (size);
                _gradLayer.Frame = new RectangleF (0, 0, size.Width, size.Height);
    I hope this helps!
    -SteveZ
