630
Bubble and Scatter with Many Data Points (>~2500) Causes Error
I have a Bubble series with many data points and custom markers, sometimes over 2500. In those cases, the chart generation fails. I have also tried using the default markers with no success. I also see the same issues when using Scatter as well. I attached a sample project that you provided regarding one of my previous questions since it suited my situation nicely, and all I had to do was increase the number of data points. I documented my findings in the ViewController.m file, as well as below. I am using the latest OSX, Xcode, and iOS, and 2014.1.
1. Single BubbleSeries and custom markers with a lot of data points.
- Only add _firstSource to the chart.
- Increase number of data points to 2500.
- Error on startup: EXC_BAD_ACCESS
2. I thought Issue #1 may have been caused by custom markers, but not so.
- Remove the chart delegate setting so that custom markers are not used.
- Keep number of data points at 2500.
- And if no error on startup, then it definitely occurs on rotation: EXC_BAD_ACCESS
- If not the EXC_BAD_ACCESS error, then it is a "iGChart_LegendWithCustomMarkers(58695,0x243e1a8) malloc: *** error for object 0x106dfcd4: incorrect checksum for freed object - object was probably modified after being freed."
3. Then I though maybe it was just Bubble, and so I tried Scatter, but not so.
- Change to Scatter helper and series.
- Only add the _firstSource to the chart.
- Keep delegate set so custom markers are still used, but make sure to hard code the radius since there is no IGBubblePoint anymore
- Same error on startup: iGChart_LegendWithCustomMarkers(58808,0x243e1a8) malloc: *** error for object 0xaf5aac4: incorrect checksum for freed object - object was probably modified after being freed.
4. The same thing happens with Scatter and no custom markers, just like case #2.
5. The only thing I found to work was to use Scatter with no custom markers, AND NO DEFAULT MARKER, whenever a series had a data with over 2000 data points.
- Keep Scatter, 2500 points, but remove chart delegate setting, and set marker type to IGMarkerTypeNone.
- The IGMarkerTypeNone solution (hack) only works for Scatter. It didn't seem to work when using Bubble series.
- I also use a trendline, so not having the markers show is not a deal breaker, but also not ideal.
So what I've been doing is checking to see if any of my series have more than 2000 data points, then I switch to no custom markers and IGMarkerTypeNone on that particular series. Otherwise I can use the Bubble or Scatter as intended with custom markers. If I lower the number of data points per series to something usually under 2000, it generally works fine, but I'm not 100% sure about this.
iGChart_LegendWithCustomMarkers.zip
  • 29105
    Hello Jeff,
    I have opened a private case for you so that I can link it to an internal development issue. This way you will be notified automatically when the dev issue is updated. You will receive an email regarding this and the case number is CAS-137175-C1W4D4. You will see it located here: https://ko.infragistics.com/my-account/support-activity
    Let me know if you have any questions regarding this matter.
  • 29105
    Hello Jeff,
    Thank you for reporting this behavior. I have successfully reproduced the behavior as you described and reached out to our developers on the matter. I will update you as soon as I have more information. If needed we may need to transition this conversation to a private case to continue our investigation. In the meantime I will priortize our resources to provide you with a timely response. Let me know if you have any questions regarding this matter.
