We're having an intermittent issue - when on a day cell on a calendar view has more appointments than can be displayed, so an "x more..." message is displayed it can cause some AppoinmentOrbs not to be rendered. There doesn't seem to be any pattern to this, but we have isolated it to the "x more..." being displayed. If we open this in reveal, then select the invisible appointment orb and enable the "ClipToBounds" property then the orb is displayed correctly - though it still appears if we disable the property, so it could just be that this triggers the cell to render again.
We have a workaround for this, but it's far from ideal. We created a custom appointment with the appropriate "x more..." text and set the appointment orb alpha to 0.
Is this a known issue? Could you provide a date for a fix? I would suggest for a future release, if you could open up the calendar data controls/model to be more traversable to make any necessary workarounds easier.
See Saturday 2nd on the following screenshot:
Hi Michael,
I have a similar issue and I did download service release. (the file I am using is IG.Unified.dll from 1/26/2015 v2.0.50727)
Say in portrait mode I have "x more" showing up initially ok, once I rotate to landscape all 'x more" disappear. They will reappear again once I scroll to the next month.
Again as in reported case, some of the entries have the same name.
Any suggestions?
Thanks you
Mark
Hello Paul,
This issue has been addressed in the latest service release. This service release is now available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page.
Let me know if you have any additional questions.
I have opened a private case for you so that I can link it to an internal development issue. This way you will be notified automatically each time the development issue is updated. The case number is CAS-141105-M9Y4L6. You will see it located here: https://ko.infragistics.com/my-account/support-activity
If you have any questions regarding this matter please update the support case. Thanks.
Hi Paul,
Thanks for the detailed description.
I was able to identify the issue, and it'll be fixed in the next version. Someone from support will contact you shortly and create a case so that you're notified when the fix is released.
-SteveZ
