Is there a built-in way to just show a configurable message below the headers when the datasource contains no data? I have been building in logic to flip Hidden between a UILabel and the grid, as well as code to position both of them. It would save some time if this were already built in on the grid. Thanks!
Hello Michael,
I am just checking about the progress of this issue. Let me know if you need our further assistance on it.
The IGGridView currently doesn't have this feature built-in. I recommend submitting this idea to our NucliOS Ideas page.
Despite not being built-in, one way you can achieve this is by creating a class that inherits from IGGridViewDataSourceHelper and overriding the gridView:numberOfRowsInSection: method. If the data count is 0 then set the backgroundView of the IGGridView, otherwise remove the backgroundView and return the number of rows. An example is attached to this post demonstrating this solution.
Note: The IGGridView's backgroundView is automatically resized to match the size of the grid view. The view is placed as a subview of the grid view behind all cells, header views and footer views.
