Hello again,
i have a chart with one ColumnSeries and one LineSeries. The problem you can see in the attached image. The top graphic (build with an other control) is ok. The bottom part of the image is the nuclios chart.
Thanks for helping
Johann
if i use the same xAxis for both series it works. I had different axes for x and y.....
Hello Johann,
Thank you for contacting Infragistics.
I've attached a sample project which has a line series and a column series connected to the same axes. I'd like you to compare my sample with your project to see if you may be missing anything. When I run my sample, the points for the line series are horizontally centered on each column.
