785
Prevent RowSelection when Custom Switch Column Value is Changed
I'm wondering what is the best way to prevent a Row from being selected when a change is made to a custom column that contains a UISwitch. I have my custom GridViewColumnDefinition which contains a custom IGgridViewCell which contains my UISwitch. That switch implements the ValueChanged Event Handler. I execute some code when the value changes, but don't want the row to be selected because that executes some other code specific to DidSelectRow.
Anyways, I believe you get my point by now, I'm leaning towards overriding the WillSelectRow method and doing a HitTest to see which Column was pressed at the time when a selection was performed, but I'm not sure if this is the correct approach. Looking for the best approach to precent the DidSelectRow method from firing when a specific column is clicked.
Thanks for all you help as always.
  • 40030
    Verified Answer
    Its actually pretty easy to do. In your custom cell, just add the following method along with the export attribute:
    [Export("selectGesture:")]
            public void overrideSelectGesture(UIGestureRecognizer gesture)
                // Do Nothing
    Basically, this overrides the cell's selection gesture, and thus disables selection via that cell.
    I've attached a sample that does exactly that.
    Hope this helps,
    -SteveZ
    GridSample.zip
