630
Candlestick High/Low Lines Don't Render?
Is there a known issue with the Candlestick style financial chart in iOS 8.1 or 8.1.1 where the high/low lines don't render?
Even in the NucliOS iOS app available via the App Store, the Candlestick style example doesn't render the high/low lines either (except briefly on the last few data points, and even then not reliably). The open/close box is fine. I am running iPad Air, 8.1.1.
The only alternative I can think of at this point is to use a RangeColumnSeries for the box, and then maybe a bunch of scatter line series to get the vertical line.
Thanks.
  • 48586
    Hello ,
    I was able to reproduce this and I’ve created a case in our issue taking system in order to continue investigating this. Your case id is CAS-147444-F2F5K6 and I will update you, via the case,  for the progress of this issue as soon as I have more information for you.
    Thank you for your understanding.
