Crashlytics is recording a crash that occurred several times with at least one of our customers: when setting the "data" object of our IGGridViewDataSourceHelper object the following exception is thrown: "Objective-C exception thrown. Name: NSInvalidArgumentException Reason: *** setObjectForKey: key cannot be nil "
I found this post: "monotouch: IGGridView.UpdateData() with custom header cell gives error" but we are not overriding any of the CreateCell-methods.
The problem is that we are unable to reproduce the bug on our development system. Here's the piece of code that seems to be causing the crashs:
dataSource.Data = _hpAktivitaeten.ToArray(); gridView.WeakDataSource = dataSource; gridView.UpdateData();
DataSource is derived from IGGridViewDataSourceHelper with overrides for "ApplyFilter" and "ResizeColumn". _hpAktivitaeten is a list of our data objects.
What can cause this kind of exception? Any help would be appreciated!
Thanks in advance
Andreas
Hello Andreas,
While investigating more into this issue if you happen to have any additional questions please let us know.
Hi Steve,
unfortunately the crash reports of Crashlytics don't give more information than I posted earlier. That's why we're having a hard time locating/reproducing the issue.
Anyway thank you for your answer!
Greetings, Andreas
Hi Andreas,
Honestly, its really hard to say whats causing the issue without a bit more information. If you had a stack trace that could help narrow it down.
Basically what happens when you set the data, is that we first try to generate any columns that need to be auto generated, we do this by looking at the first row of data. Then we apply any Grouping, Filtering and Sorting that is necessary. Thats basically it. I don't believe we set any properties, there, as your error would imply, so i'm really not sure why that exception is happening...
I'm sorry I can't be of more help here.
-SteveZ
