630
Problem with unified api dll
IG.Unified.dll and IGChart.Unified.dll (12/15/2014) did work with actual Xamarin BETA version at 12/18/2014
but does not work with actual Xamarin STABLE version.
Code sample:
nfloat width = 150;
col.Width = IGColumnWidth.CreateNumericColumnWidth(width);
produces a System.Exception:
 Failed to marshal the Objective-C object 0x7a0a2f80 (type: IGColumnWidth).
Could not find an existing managed instance for this object, nor was it possible to create
a new managed instance (because the type 'Infragistics.IGColumnWidth' does not have a constructor that takes one IntPtr argument).
at ObjCRuntime.Runtime.MissingCtor (IntPtr ptr, IntPtr klass, System.Type type, MissingCtorResolution resolution) [0x00046] in
/Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:392
at ObjCRuntime.Runtime.ConstructNSObject[IGColumnWidth] (IntPtr ptr, System.Type type, MissingCtorResolution missingCtorResolution) [0x0002a] in
/Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:415
at ObjCRuntime.Runtime.GetNSObject[IGColumnWidth] (IntPtr ptr) [0x000c1] in
/Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:521
at Infragistics.IGColumnWidth.CreateNumericColumnWidth (nfloat width) [0x00000] in <filename unknown>:0
Thans for helping
Johann
  • 4940
    Verified Answer
    Offline posted in reply to Johann Geßler
    Hi Johann,
    By looking at the log that you pasted, I can see the error involves some slices missing from the embedded static library that resides in the Infragistics assembly.
    MTOUCHTASK:  warning MT1301: Native library `libigLib.a` (i386, armv7, arm64) was ignored since it does not match the current build architectures (i386, x86_64)
    This issue doesn't exist in the latest SR, which was released 2 weeks ago. To verify I extracted the static library from the assembly and tested to view the included architecture slices.
    To grab the latest SR, visit https://ko.infragistics.com/my-account/keys-and-downloads and click on the 2014.2 product, then the Service Releases tab. Before installation, make sure to wipe out the "/Developer/Infragistics/NUCLiOS 2014 Volume 2" path. Also close Xcode and Xamarin Studio before the installation. After the installation, clean your project and rebuild.
    [Edit]: Upon doing further research, despite the embedded static library containing all the necessary architecture slices, the Xamarin wrapper didn't contain the necessary LinkType to inform Xamarin Studio to the existence of the x86_64 slice. We'll rebuild with the necessary change and work on providing an updated SR.
  • 630
    Offline posted in reply to Torrey Betts
    Hi Torrey,
    we have problems with the simulator Build with 64bit support.
    When i eliminate the usage of the actual IG.Unified.dll i can build a Simulator Version "i386+x86_64" of the application, we delivered to you, but the build fails when i have the usage as in the version we provided to you. Tell me if you need the sample again.
    Thanks, Johann
    Log:
    Popovers (Debug|iPhoneSimulator) wird erzeugt
    Build started 22.01.2015 15:22:03.
    __________________________________________________
    Project "/Users/gdo/Samples/TEST/Popovers.csproj" (Build target(s)):
                    Target PrepareForBuild:
                                   Configuration: Debug Platform: iPhoneSimulator
                    Target _DetectAppManifest:
                                   FindItemWithLogicalName Task
                                     Items:
                                       Info.plist
                                     LogicalName: Info.plist
                                     ProjectDir: /Users/gdo/Samples/TEST
                                     ResourcePrefix: Resources
                    Target _DetectSdkLocations:
                                   DetectSdkLocations Task
                                     SdkVersion: 8.1
                                     XamarinSdkRoot: /Library/Frameworks/Xamarin.iOS.framework/Versions/Current
                    Target _CoreCompileInterfaceDefinitions:
                                   IBTool Task
                                     AppManifest: Info.plist
                                       en.lproj/DetailView.xib
                                       en.lproj/MainWindow.xib
                                     IntermediateOutputPath: obj/iPhoneSimulator/Debug/
                                     SdkBinPath: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator8.1.sdk/Developer/usr/bin
                                     SdkRoot: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator8.1.sdk
                                     SdkVersion: 8.1
                    Target _CollectColladaAssets:
                                   CollectBundleResources Task
                                     BundleResources: <null>
                                     OptimizePNGs: False
                    Target _CoreCompileColladaAssets:
                    No input files were specified for target _CoreCompileColladaAssets, skipping.
                    Target _CoreCompileSceneKitAssets:
                                   CompileSceneKitAssets Task
                                     SceneKitAssets:
                                     SdkDevPath: /Applications/Xcode.app/Contents/Developer
                                     SdkVersion: 8.1
                    Target _CoreCompileTextureAtlases:
                                   TextureAtlas Task
                                     AtlasTextures: <null>
                                     SdkUsrPath: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator8.1.sdk/Developer/usr
                    Target _CollectITunesArtwork:
                                   CollectITunesArtwork Task
                                     ITunesArtwork:
                                       Resources/iTunesArtwork.png
                    Target _CollectBundleResources:
                                     BundleResources:
                                       Resources/Default-568h@2x.png
                                       Resources/Default-Landscape@2x~ipad.png
                                       Resources/Default-Landscape~ipad.png
                                       Resources/Default-Portrait@2x~ipad.png
                                       Resources/Default-Portrait~ipad.png
                                       Resources/Default.png
                                       Resources/Default@2x.png
                                       Resources/iTunesArtwork@2x.png
                                       Resources/icon-100.png
                                       Resources/icon-114.png
                                       Resources/icon-144.png
                                       Resources/icon-29.png
                                       Resources/icon-50.png
                                       Resources/icon-57.png
                                       Resources/icon-58.png
                                       Resources/icon-72.png
                                     OptimizePNGs: True
                    Target _CoreOptimizePngImages:
                    Skipping target "_CoreOptimizePngImages" because its outputs are up-to-date.
                    Target _UnpackLibraryResources:
                                   UnpackLibraryResources Task
                                     Prefix: monotouch
                                     ReferencedLibraries:
                                       /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.dll
                                       /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Xml.dll
                                       /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/Xamarin.iOS.dll
                                       ../IG.Unified.dll
                                       /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Core.dll
                                       /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/mscorlib.dll
                    Target GenerateSatelliteAssemblies:
                    No input files were specified for target GenerateSatelliteAssemblies, skipping.
                    Target GenerateTargetFrameworkMonikerAttribute:
                    Skipping target "GenerateTargetFrameworkMonikerAttribute" because its outputs are up-to-date.
                    Target CoreCompile:
                                   Tool /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/bin/smcs execution started with arguments: /noconfig /debug:full /debug+ /optimize- /out:obj/iPhoneSimulator/Debug/Popovers.exe Main.cs AppDelegate.cs RootViewController.cs RootViewController.designer.cs PopoverContentViewController.cs PopoverContentViewController.designer.cs DetailViewController.cs DetailViewController.designer.cs /target:exe /define:"__UNIFIED__;__MOBILE__;__IOS__;DEBUG" /nostdlib /reference:/Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.dll /reference:/Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Xml.dll /reference:/Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/Xamarin.iOS.dll /reference:../IG.Unified.dll /reference:/Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Core.dll /reference:/Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/mscorlib.dll /warn:4
    AppDelegate.cs(13,19): warning CS0114: `Popovers.AppDelegate.Window' hides inherited member `UIKit.UIApplicationDelegate.Window'. To make the current member override that implementation, add the override keyword. Otherwise add the new keyword
                                   /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/Xamarin.iOS.dll (Location of the symbol related to previous warning)
    DetailViewController.cs(115,13): warning CS0219: The variable `tappedButton' is assigned but its value is never used
                    Target DeployOutputFiles:
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Popovers.exe.mdb' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.exe.mdb'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Popovers.exe' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.exe'
                    Target _DetectSigningIdentity:
                                   DetectSigningIdentity Task
                                     AppBundleName: Popovers
                                     RequireCodesigning: False
                                     ProvisioningProfile: <null>
                                     SigningKey: iPhone Developer
                    Target _CopyContentToBundle:
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/ibtool/en.lproj/DetailView.nib' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/en.lproj/DetailView.nib'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/ibtool/en.lproj/MainWindow.nib' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/en.lproj/MainWindow.nib'
                                   Copying file from '/Users/gdo/Samples/TEST/Resources/iTunesArtwork.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/iTunesArtwork'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default-568h@2x.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default-568h@2x.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default-Landscape@2x~ipad.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default-Landscape@2x~ipad.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default-Landscape~ipad.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default-Landscape~ipad.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default-Portrait@2x~ipad.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default-Portrait@2x~ipad.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default-Portrait~ipad.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default-Portrait~ipad.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/Default@2x.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/Default@2x.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/iTunesArtwork@2x.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/iTunesArtwork@2x.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-100.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-100.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-114.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-114.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-144.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-144.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-29.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-29.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-50.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-50.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-57.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-57.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-58.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-58.png'
                                   Copying file from '/Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/icon-72.png' to '/Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/icon-72.png'
                    Target _CompileAppManifest:
                    Skipping target "_CompileAppManifest" because its outputs are up-to-date.
                    Target _CompileToNative:
                                   MTouch Task
                                     AppBundleDir: bin/iPhoneSimulator/Debug/Popovers.app
                                     AppManifest: bin/iPhoneSimulator/Debug/Popovers.app/Info.plist
                                     Architecture: i386, x86_64
                                     CompiledEntitlements: obj/iPhoneSimulator/Debug/Entitlements.xcent
                                     Debug: True
                                     EnableGenericValueTypeSharing: True
                                     Entitlements: <null>
                                     ExtraArgs: <null>
                                     FastDev: False
                                     I18n: <null>
                                     IntermediateOutputPath: obj/iPhoneSimulator/Debug/mtouch-cache
                                     IsAppExtension: False
                                     LinkMode: SdkOnly
                                     MainAssembly: /Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug//Popovers.exe
                                     NativeReferences: <null>
                                     OutputPath: bin/iPhoneSimulator/Debug/
                                     Profiling: False
                                     ProjectFullPath: /Users/gdo/Samples/TEST/Popovers.csproj
                                     References:
                                       ../IG.Unified.dll
                                       ../IG.Unified.dll
                                     SdkVersion: 8.1
                                     TargetFrameworkIdentifier: Xamarin.iOS
                                     UseLlvm: False
                                     UseRefCounting: False
                                     UseSGen: False
                                     UseThumb: False
                                   Tool /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/bin/mtouch execution started with arguments: --cache /Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/mtouch-cache --sim /Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app --executable Popovers --debug --linksdkonly --sdkroot /Applications/Xcode.app/Contents/Developer --sdk 8.1 --targetver 8.1 --abi=i386,x86_64 -r /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.dll -r /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Xml.dll -r /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/Xamarin.iOS.dll -r ../IG.Unified.dll -r /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/System.Core.dll -r /Library/Frameworks/Xamarin.iOS.framework/Versions/Current/lib/mono/Xamarin.iOS/mscorlib.dll -r ../IG.Unified.dll /Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug//Popovers.exe
                                   Xamarin.iOS 8.6.0 Business Edition using framework: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator8.1.sdk
                                   Process exited with code 1, command:
                                   /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang  -Wl,-pie  -arch x86_64 -gdwarf-2 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator8.1.sdk -Qunused-arguments -fobjc-legacy-dispatch -fobjc-abi-version=2 -mios-simulator-version-min=8.1 /Users/gdo/Samples/TEST/obj/iPhoneSimulator/Debug/mtouch-cache/main.x86_64.o -o /Users/gdo/Samples/TEST/bin/iPhoneSimulator/Debug/Popovers.app/.monotouch-64/Popovers -framework QuartzCore -framework EventKit -framework Foundation -framework CoreGraphics -framework UIKit -framework CFNetwork -lz -liconv -u _mono_pmip -u _kFilterRowIndex -u _kHeaderRowIndex -u _kPullDownRowIndex -u _kSectionFooterIndex -u _kSectionHeaderIndex -u _IGTextStyleBackgroundColorAttributeName -u _IGTextStyleBoldAttributeName -u _IGTextStyleFontAttributeName -u _IGTextStyleForegroundColorAttributeName -u _IGTextStyleItalicAttributeName -u _IGTextStyleKernAttributeName -u _IGTextStyleStrokeColorAttributeName -u _IGTextStyleStrokeWidthAttributeName -u _IGTextStyleTapAttributeName -u _IGTextStyleUnderlineAttributeName -u _IGTextStyleUnderlineColorAttributeName -u _monotouch_timezone_get_data -u _monotouch_log -u _xamarin_release_managed_ref -u _xamarin_create_managed_ref -u _xamarin_get_block_descriptor /Library/Frameworks/Xamarin.iOS.framework/Versions/8.6.0.51/SDKs/MonoTouch.iphonesimulator.sdk/usr/lib/libmonosgen-2.0.a /Library/Frameworks/Xamarin.iOS.framework/Versions/8.6.0.51/SDKs/MonoTouch.iphonesimulator.sdk/usr/lib/libmonotouch-sgen-debug.a /Library/Frameworks/Xamarin.iOS.framework/Versions/8.6.0.51/SDKs/MonoTouch.iphonesimulator.sdk/usr/lib/libapp.a
                                   Undefined symbols for architecture x86_64:
                                     "_IGTextStyleBackgroundColorAttributeName", referenced from:
                                        -u command line option
                                     "_IGTextStyleBoldAttributeName", referenced from:
                                     "_IGTextStyleFontAttributeName", referenced from:
                                     "_IGTextStyleForegroundColorAttributeName", referenced from:
                                     "_IGTextStyleItalicAttributeName", referenced from:
                                     "_IGTextStyleKernAttributeName", referenced from:
                                     "_IGTextStyleStrokeColorAttributeName", referenced from:
                                     "_IGTextStyleStrokeWidthAttributeName", referenced from:
                                     "_IGTextStyleTapAttributeName", referenced from:
                                     "_IGTextStyleUnderlineAttributeName", referenced from:
                                     "_IGTextStyleUnderlineColorAttributeName", referenced from:
                                     "_kFilterRowIndex", referenced from:
                                     "_kHeaderRowIndex", referenced from:
                                     "_kPullDownRowIndex", referenced from:
                                     "_kSectionFooterIndex", referenced from:
                                     "_kSectionHeaderIndex", referenced from:
                                   ld: symbol(s) not found for architecture x86_64
                                   clang: error: linker command failed with exit code 1 (use -v to see invocation)
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleBackgroundColorAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleBackgroundColorAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleBoldAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleBoldAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleFontAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleFontAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleForegroundColorAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleForegroundColorAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleItalicAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleItalicAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleKernAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleKernAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleStrokeColorAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleStrokeColorAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleStrokeWidthAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleStrokeWidthAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleTapAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleTapAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleUnderlineAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleUnderlineAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _IGTextStyleUnderlineColorAttributeName. This symbol was referenced the managed member Infragistics.IGLabelConstants.IGTextStyleUnderlineColorAttributeName. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _kFilterRowIndex. This symbol was referenced the managed member Infragistics.IGGridViewConstants.kFilterRowIndex. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _kHeaderRowIndex. This symbol was referenced the managed member Infragistics.IGGridViewConstants.kHeaderRowIndex. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _kPullDownRowIndex. This symbol was referenced the managed member Infragistics.IGGridViewConstants.kPullDownRowIndex. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _kSectionFooterIndex. This symbol was referenced the managed member Infragistics.IGGridViewConstants.kSectionFooterIndex. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5214: Native linking failed, undefined symbol: _kSectionHeaderIndex. This symbol was referenced the managed member Infragistics.IGGridViewConstants.kSectionHeaderIndex. Please verify that all the necessary frameworks have been referenced and native libraries linked.
    MTOUCHTASK: error MT5202: Native linking failed. Please review the build log.
                    Task "MTouchTask" execution -- FAILED
                    Done building target "_CompileToNative" in project "/Users/gdo/Samples/TEST/Popovers.csproj".-- FAILED
    Done building project "/Users/gdo/Samples/TEST/Popovers.csproj".-- FAILED
    Build FAILED.
    Warnings:
    /Users/gdo/Samples/TEST/Popovers.csproj (Build) -> /Library/Frameworks/Mono.framework/Versions/3.12.0/lib/mono/4.5/Microsoft.CSharp.targets (CoreCompile target) ->
    /Users/gdo/Samples/TEST/Popovers.csproj (Build) -> /Library/Frameworks/Mono.framework/External/xbuild/Xamarin/iOS/Xamarin.iOS.Common.targets (_CompileToNative target) ->
    Errors:
    --------------------- Fertig ---------------------
    Build: 17 Fehler, 4 Warnungen
  • 630
    Hi Torrey,
    i can provide you a sample on our server. Here is the link: https://www.hidrive.strato.com/lnk/wEmIGLCS
    Test.zip contains an adjusted Xamarin Popovers Sample with IG.Unified.dll which leads to an Exception using it:
    Tap on “Tap” and the mentioned exception is thrown:
    2015-01-09 10:44:48.707 Popovers[1728:35392] System.Exception: Failed to marshal the Objective-C object 0x18dd8550 (type: IGColumnWidth). Could not find an existing managed instance for this object, nor was it possible to create a new managed instance (because the type 'Infragistics.IGColumnWidth' does not have a constructor that takes one IntPtr argument).
      at ObjCRuntime.Runtime.MissingCtor (IntPtr ptr, IntPtr klass, System.Type type, MissingCtorResolution resolution) [0x00046] in /Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:392
      at ObjCRuntime.Runtime.ConstructNSObject[IGColumnWidth] (IntPtr ptr, System.Type type, MissingCtorResolution missingCtorResolution) [0x0002a] in /Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:415
      at ObjCRuntime.Runtime.GetNSObject[IGColumnWidth] (IntPtr ptr) [0x000c1] in /Developer/MonoTouch/Source/maccore/src/ObjCRuntime/Runtime.iOS.cs:521
      at Popovers.DetailViewController.ShowPopover (Foundation.NSObject sender) [0x00015] in /Users/gdo/Samples/TEST/DetailViewController.cs:125
    In DetailsViewController.cs:
            public void ShowPopover (NSObject sender) {
                // Set the sender to a UIButton.
                UIButton tappedButton = (UIButton)sender;
                // for TEST
                // Present the popover from the button that was tapped in the detail view.
                //DetailViewPopover.PresentFromRect (tappedButton.Frame, View, UIPopoverArrowDirection.Any, true);
                try {
                    nfloat width = 150;
                    IGColumnWidth columnWidth = IGColumnWidth.CreateNumericColumnWidth (width);
                    Console.WriteLine (columnWidth.ToString ());
                } catch (Exception e) {
                    Console.WriteLine (e);
                // Set the last button tapped to the current button that was tapped.
                LastTappedButton = sender;
    Johann
  • 4940
    Hi Johann,
    I tested the following lines of code using Xamarin Studio 5.5.4-5.7 and did not encounter any exceptions.
    nfloat width = 150;
    IGColumnWidth columnWidth = IGColumnWidth.CreateNumericColumnWidth(width);
    Would you be able to attach a sample to your next reply that causes an exception with the code you mentioned? Additionally, you may want to place your IGColumnWidth instance into a instance variable so there is no chance it would get released before assigning the Width property of IGGridViewColumnDefinition.
