I have a similar issue to http://ko.infragistics.com/community/forums/t/91155.aspx
and I did download service release. (the file I am using is IG.Unified.dll from 1/26/2015 v2.0.50727)
Say in portrait mode I have "x more" showing up initially ok, once I rotate to landscape all 'x more" disappear. They will reappear again once I scroll to the next month.
Is this suppose to work with latest service release update?
Thanks you
Mark
Hey Mark,
I'm doing well, thanks!
In the MonthView, you can stop our appointments from displaying, and display you're own custom UI. However, we don't currently offer that in the (day/week views)
The more info you can give on what you're trying to achieve the better. What you have listed there is a good start.
Also, we use our ideas page to drive what features get included. If you could make sure you add your suggestion to that page, and vote it up, then we can add the feature sooner!
http://ideas.infragistics.com/forums/211525-nuclios/
Thanks!
-SteveZ
Hi Stephen,
Hope all is well....
Is anything changed as far as being able to create a custom appointment cells? The need we have is for the cell to display some custom fields in it such as icons, or some UI attributes as shorter width and rounded corners for example.
Thank you
An SR containing this fix has been made available. You should receive an email notifying you where you can download the fix.
The next SR should be out in the next couple of weeks.
As for custom appointment cells, thats not currently possible. However, if you could describe what you'd like to accomplish, and post it on our ideas page(http://ideas.infragistics.com/forums/211525-nuclios) it would help to make sure we get the feature right when we add it.
Thank you Steve for response
When do you think the next release is going to come out? We can wait if it is coming out soon.
While I am on it, is it possible to custom draw cells in Day view of the calendar?
