jwinkler2083233 said:The install for NA for winforms threw up an error from the browser saying 'cannot find ....\samples\...'
I would recommend submitting this issue to the support group: http://ko.infragistics.com/gethelp.
My client just purchased every possible license.
I can't find a sample for the docking manager. I have all the sources for ultrawinXYZ, but no project for the docking sample.
I've wasted way too much time... so I thought I'd post this. Now what?
You can check the UltraDockManager.ActivePane property. That will return a DockableControlPane. I don't think there is a public way to get directly to the DockableWindow which contains the pane, but you can get it's Control property and then get that control's Parent property:
DockableControlPane pane = this.ultraDockManager1.ActivePane;
if ( pane != null ){ DockableWindow activeDockableWindow = pane.Control.Parent as DockableWindow;
if ( activeDockableWindow != null ) { // ... }}
