Is there any way to do the following in ultraGrid?
1. Remove the blank rows at the end.
2. Remove the dotted outline of the selected row (I am using preset Aero)
Any help will be highly appreciated.
Sameer
Hi Sameer,
1) What blank rows are you referring to? There are no blank rows in the grid by default. Perhaps you have turned on the EmptyRows feature? Or maybe you have AllowAddNew set to display an AddNew row?
2) I think the dotted outline you are referring to must be the focus rectangle. This KB article should help: HOWTO:How can I turn off the Focus Rectangle on an Infragistics Win Control?
