100
Composite Gantt Chart
I've had a Gantt chart working fine for a while binding to a datatable with columns (GanttSeries, GanttTask, GanttStart, GanttEnd). Im now trying to turn this into a composite chart to layer two gantt charts on top of each other. I have a composite chart working with linechart (based on the doc example) so I copied this and adapted for the Gantt but its not working.
I've constructed the Gantt series manually so I can work with my existing DAL and the above data table.
Can anyone see what im doing wrong?
private Dictionary<string,GanttSeries> CreateGanttSeries(DataTable table, bool background)
Dictionary<string,GanttSeries> results = new Dictionary<string,GanttSeries>();foreach (DataRow row in table.Rows)
GanttSeries value;
if( !results.TryGetValue(row["GanttSeries"].ToString(), out value) ) {results.Add(row["GanttSeries"].ToString(), new GanttSeries(row["GanttSeries"].ToString()));
GanttItem item = new GanttItem();
item.Key = row["GanttTask"].ToString();
DateTime starttime = (DateTime)row["GanttStart"];
DateTime endtime = (DateTime)row["GanttEnd"];
item.Times.Add(new GanttTimeEntry(starttime,endtime));
results[row["GanttSeries"].ToString()].Items.Add(item);
return results;
private void FormatGanttChart(DateTime starttime, DateTime endtime)
this.ganttchart1.CompositeChart.ChartLayers.Clear();
this.myChartArea.Axes.Clear();
//Create New Axis
globalAxisX = new AxisItem();
globalAxisX.OrientationType = AxisNumber.X_Axis;
globalAxisX.DataType = AxisDataType.Time;
globalAxisX.SetLabelAxisType = SetLabelAxisType.ContinuousData;
globalAxisX.Labels.Orientation = TextOrientation.VerticalLeftFacing;
globalAxisX.LineThickness = 1;
globalAxisX.RangeType =
AxisRangeType.Custom;
globalAxisX.RangeMin = starttime.Ticks;
globalAxisX.RangeMax = endtime.Ticks;
globalAxisY =
new AxisItem();
globalAxisY.OrientationType = AxisNumber.Y_Axis;
globalAxisY.RangeType = AxisRangeType.Automatic;globalAxisY.DataType = AxisDataType.String;
globalAxisY.LineThickness = 1;
myChartArea.Axes.Add(globalAxisX);
myChartArea.Axes.Add(globalAxisY);
ChartLayerAppearance layer = new ChartLayerAppearance();
layer.ChartArea = myChartArea;
layer.AxisX = globalAxisX;
layer.AxisY = globalAxisY;
Dictionary<string, GanttSeries> mainseries = CreateGanttSeries(this.ds_GanttChart, false);foreach (KeyValuePair<string, GanttSeries> serieskvp in mainseries)
layer.Series.Add(serieskvp.Value);
this.ganttchart1.CompositeChart.ChartLayers.Add(layer);
