Using UltraGridExcelExporter.Export() to export ultra grid data to Excel.
But the downloaded file has error, and there are no errors during the exporting. The error information is in the attachment.
Had any body also met this problem?
The key problem is that there are no errors during exporting, so I can't debug.....
A similar bug has been reported and fixed. I would recommend upgrading to the latest hotfix for the version you are using. If it does not fix the issue, you can submit the issue here: http://ko.infragistics.com/gethelp.
I found it caused by the non-ASCII text in the ultragrid, such as chinese word or special signal.
