I have an ultra grid used for data entry. I'd like to allow the users to not have to use a mouse.
I added a column with style editor button. When the user enters into this field, I'd like them to be
able to optionally simulate a mouse click on the button without having to use a mouse. Is there a
way to set focus to the button or is there a hot key combination that will simulate the button click?
Rick
Hi Rick,
Although it's possible to simulate a mouse click in Windows, I don't recommend handling this that way.
Instead, you could handle the grid's KeyPress event and look for the desired shortcut key combination. From there, you could call the same logic that occurs in the button click handler. The code might look something like this:
private void ultraGrid1_KeyPress(object sender, KeyPressEventArgs e){ switch (e.KeyChar) { case Keys.E: if (ModifierKeys.HasFlag(Keys.Control)) { OpenStyleEditor(); } default: break; }}
In this example, the OpenStyleEditor method would contain the logic that runs when a user clicked the style editor button. Please let me know if this works.
