1706
Save column position & size - (Infragistics 2013 Volume 1)
Is there a simple way to load and save basic column info such as position, size, and sort based on the key, without saving other column data such as its max and min values?
I looked into the DisplayLayout's Save method, but it is not 100% clear to me what is being saved and each option seems like it is saving significantly more info than desired, making it difficult to update that info in the code and prevent the client's "Layout" information from reverting that.
Any insight on this would be appreciated.
Thank you.
