40
Cast exception UltraGridRow to UltraGridGroupByRow
We recently encountered the same issue reported in the below thread.
http://ko.infragistics.com/community/forums/p/32111/488193.aspx#488193
System.InvalidCastException: Unable to cast object of type 'Infragistics.Win.UltraWinGrid.UltraGridRow' to type 'Infragistics.Win.UltraWinGrid.UltraGridGroupByRow'.
   at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRows_Add(UltraGridRow row, Int32 desiredIndex)
   at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRowsHelper(IList boundList)
   at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRows()
   at Infragistics.Win.UltraWinGrid.RowsCollection.VerifyGroupByVersionHelper()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.get_ParentRow()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.get_HiddenResolved()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.get_FirstRow()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.GetMaxScrollPosition(Boolean scrollToFill)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.RowScrollRegionsCollection.AreScrollbarsVisible(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.ColScrollRegion.ResetScrollInfo()
   at Infragistics.Win.UltraWinGrid.ColScrollRegion.RegenerateVisibleHeaders()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.PositionScrollbar(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.ResizeRowScrollRegions()
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements()
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.InternalInitializeRect(Boolean verify)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetUIElement(Boolean verify, Boolean forceInitializeRect)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam): Unable to cast object of type 'Infragistics.Win.UltraWinGrid.UltraGridRow' to type 'Infragistics.Win.UltraWinGrid.UltraGridGroupByRow'.
It is not so easy to reproduce. Sometimes it occurs when the grid view is brought to front. What could be the cause of this error?
