Hi everybody!
I'm using UltraDataGrid and I want to have one of my columns to be changed in a ComboBox manner - select from set of predefined values.
Another column I wanna edit in a DateTimePicker style.....
Well - the only question is HOW to implement this in runtime (and in designtime also)
Thanks in advance!
Thanks a lot, Mike, for quick and precise response ))
To provide a dropdown list in a cell of the grid, check out this KB article:
HOWTO:What is the best way to place a DropDown list in a grid cell?
Regarding the DateTimePicker, the grid will automatically use the approriate editor for a column based on the column's DataType. So you probably just need to make sure the column in this case is of the DateTime datatype.
You can also set the Style of a column, or set it's Editor or EditorControl to have finer control over the column's editor. But the DateTimeEditor property won't work on a column that is not a DateTime type.
