When I am tabbing out from the numeric editor text box ,it seems to be automatically rounding is happening. But there is an issue with the below input.
I am inputting "12345678901234.50000", after tabout it is becoming "12345678901234.50195".
Can anyone please suggest me how to solve this issue?
Thanks & Regards
Nagaraju P
Hello Paruchuri,
Yes, you are correct. When you set NumericType property to double the precision of the displayed number is 15 – 16 digits, as the value is represented as double. This is actually the build in precision of the double type. Please note you can set the NumericType to Decimal to avoid automatic rounding. Check the attached solution where I have implement this approach.
Please let me know if you need any additional information.
