I want to prevent dockking in the bottom area of a certain DockAreaPane object.
If I use: ultraDockManager1.DefaultPaneSettings.AllowDockBottom = DefaultableBoolean.False;
that works fine, but prevents the user only from docking in the bottom area of the whole form.
I want to do something like this:
DockAreaPane areaPaneTop = new DockAreaPane(DockedLocation.DockedTop, "MyPanels");areaPaneTop.DefaultPaneSettings.AllowDockBottom = DefaultableBoolean.False;ultraDockManager1.DockAreas.Add(areaPaneTop);
It shouldn't be possible to dock anything in the bottom area of the areaPaneTop. The red line doesn't work.
How can I do this?
Thanks for your help!
Regards
Michael
Hi Mike,
I will try to build an exampe over the weekend. I let you know.
Hi Michael,
Are you able to provide more information about your requirement? Please let me know.
I think I am misunderstanding your requirement. Can you please send a screenshot of what it looks like when a pane is docked in the way you need to prevent? (Please indicate which pane is which as well).
If I can see this visually, I will have a better understanding of how to disable it.
thanks for the reply, but your suggested solution doesn't solve my issue. I can not set AllowDockTop to false for each pane because theses panes should be allowed to dock in other panes but not in areaPaneTop. In areaPaneTop only Tabbing is allowed and only by specific windows not by all windows.
Is it possible to disable the indicator in AreaPanes?
The AllowDock properties prevent the pane itself from being docked in particular ways. The code highlighted in red in your post prevents areaPaneTop from being docked to the bottom of the form.
Panes aren't really docked within each other in the way your are trying to prevent. When a user attempts to dock another pane in that spot, what's really happening is that the pane is being docked to the top. That pane can appear on the form above, below, or to either side of areaPaneTop. It would not be docked within areaPaneTop.
It would be difficult to prevent this, as a user could first dock a pane to the top of the form above dockAreaTop, then attempt to move dockAreaTop above that other pane. My recommendation is to set AllowDockTop to False on each other pane so that they cannot be docked in the same space as areaPaneTop. I would also disable AllowDragging on areaPaneTop's pane settings to enforce that it remains docked to the top of the form.
