Hello guys,
I have an UltraGrid with many rows/columns.I add a button to delete the row we have selected (n.b.: It must be possible to delete one or several rows).Here's the code that I have for the deletion :
private void DeleteButton_Click(object sender, EventArgs e) { // Check if there are any selected rows. if (this.CVaultGridExcludes.Selected.Rows.Count > 0) { // Delete the selected rows by calling DeleteSelectedRows. this.CVaultGridExcludes.DeleteSelectedRows(); } else { // Show a message if there are no selected rows. MessageBox.Show("There are no rows selected. Select rows first."); } }
I'd like to know how to store/retrieve the rows which have been chosen to be deleted in order to know what I have to modify in my DB.
I thought use an event such as AfterRowDeleted.
Or compare what I have in my DB and what I have in my UltraGrid and delete all rows which do not match.
Hello Antony,
In order to save the rows, before you delete them, you may use CopyTo method of the RowsCollection. You can use code like this:
if (this.ultraGrid1.Selected.Rows.Count > 0)
// Create a new array of rows
UltraGridRow[] selectedRows = new UltraGridRow[this.ultraGrid1.Selected.Rows.Count];
// Copy selected rows to the array before you delete them
this.ultraGrid1.Selected.Rows.CopyTo(selectedRows, 0);
this.ultraGrid1.DeleteSelectedRows();
else
Please, let me know if you need any additional information.
Hello Milko !It's super great !This is what I was looking for, thank you !
