225
UltraCombo does not show dropdown when embedded in UltraGrid
I'm currently using the 2013.2 version.  Below is a simplified version of my code.
In my FormLoad event:
    UltraCombo1.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDown
    UltraCombo1.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.SuggestAppend
    UltraCombo1.ValueMember = "StateAbbr"
    UltraCombo1.DisplayMember = "StateAbbr"  'this is not a typo
    UltraCombo1.AlwaysInEditMode = True
    UltraCombo1.DataSource = (some dataset object)
    UltraGrid1.DataSource = (some other dataset object)
In my grid_initializeLayout():
e.Layout.Bands(0).Columns("State").EditorComponent = UltraCombo1
When I run my app, the grid shows properly and the "State" column correctly shows the UltraCombo control.  When I start typing, the UltraCombo control correctly suggests and appends items.  My only problem is the UltraCombo doesn't show the dropdown when I'm typing in it.
When I comment out the following line, the same UltraCombo works as expected -- it opens the dropdown as soon as I start typing in it.
I tried to handle the KeyDown event of the UltraCombo as well as the UltraGrid as suggested in the article below.  But I can't seem to make the UltraCombo show the dropdown list.
http://ko.infragistics.com/community/forums/p/22721/83170.aspx#83170
Please help!
  • 21795
    Verified Answer
    Hello Ed,
    When you set UltraCombo as column’s EditorComponent you are using combo to visualize the data. The Style, AutocompleteMode and so on properties you should set on the column and not to the UltraCombo. So change your InitializeLayout event like this:
    Dim stateColumn As UltraGridColumn = e.Layout.Bands(0).Columns("State")
    stateColumn.EditorComponent = Me.UltraCombo1
    stateColumn.Style = ColumnStyle.DropDown
    stateColumn.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.SuggestAppend
    Please check the attached sample project where I have implement this approach and let me know if you need any additional information.
    CAS-165995-L7Y4D3.zip
