I am facing similar issue (http://ko.infragistics.com/community/forums/t/27341.aspx)
Below are snippet from code:
this.usernameTextBox.DataBindings.Add(new System.Windows.Forms.Binding("Text", this.userManagementDataSet, "users.username", true));
this.systemUsersGrid.DataMember = "users";this.systemUsersGrid.DataSource = this.userManagementDataSet;
Now, the user creates a new user using the below code :
userManagementDataSet.users.AddusersRow("NU" + _newUserCount, string.Empty, 101, "New", "User", DateTime.Now, string.Empty, string.Empty);
The dataset is updated and same is shown in textbox.
The user after editing user data closes the form
the change is not committed to the db. Saving code:
_sysUsersDa.Update(userManagementDataSet.users)
I tried the below code to try to update grid data:
var userName = usernameTextBox.Text;
systemUsersGrid.Selected.Rows[0].Cells["username"].Value = userName;
systemUsersGrid.UpdateData();
But again nothing is saved
Please suggest
Hello Pankaj,
I saw that you had created a case, #CAS-166909-S1N6R5, in our customer support system and we answered there your question.
Please check the information we have send you and let me know if you need any additional information through you case.
