280
CustomView print options not saving with workbook
I am using Crystal to export a report to excel. Then I'm trying to use the Infragistics.Excel classes to change the print options in the excel file but the changes I make are not being saved. I am using Infragistics2.Excel.v10.3. Here is my code.
Dim workbook As Infragistics.Excel.Workbook = Infragistics.Excel.Workbook.Load(excelFilePath)
Dim worksheet As Infragistics.Excel.Worksheet = workbook.Worksheets(0)
Dim customView As Infragistics.Excel.CustomView = workbook.CustomViews.Add("CustomSettings", True, True)
Dim printOptions As Infragistics.Excel.PrintOptions = customView.GetPrintOptions(worksheet)
printOptions.PaperSize = Infragistics.Excel.PaperSize.Legal
printOptions.Footer = "&RPage &P of &N"
customView.Apply()
workbook.Save(excelFilePath)
After the above code is executed I open the Excel file and none of the print options I changed have been saved. Can you tell me what I am doing wrong?
Thank you.
