75
UltraCalcManager crashes my application
When pasting a long formula with syntax error into my UltraCalcManager, the application crashes. In order to reproduce the issue, a similiar formula to the below can be used:
IF(MONTH([[T_TRADEDATE]]) = 1, "(01) January",
IF(MONTH([[T_TRADEDATE]]) = 2, "(02) February",
IF(MONTH([[T_TRADEDATE]]) = 3, "(03) March",
IF(MONTH([[T_TRADEDATE]]) = 4, "(04) April",
IF(MONTH([[T_TRADEDATE]]) = 5, "(05) May",
IF(MONTH([[T_TRADEDATE]]) = 6, "(06) June",
IF(MONTH([[T_TRADEDATE]]) = 7, "(07) July",
IF(MONTH([[T_TRADEDATE]]) = 8, "(08) August",
IF(MONTH([[T_TRADEDATE]]) = 9, "(09) September",
IF(MONTH([[T_TRADEDATE]]) = 10, "(10) October",
IF(MONTH([[T_TRADEDATE]]) = 11, "(11) November",
IF(MONTH([[T_TRADEDATE]]) = 12, "(12) December",”ERROR”
If I replace " with ', there is no syntax error and the application works good. I have tried debugging this and my thoughts are that, somehow, maybe due to all the syntax errors, the code is stuck in the recursive function that compiles the formula.
Any ideas why could this happen?
Thank you
