105
DockAreaPane layout customization
I have an UltraDockManager which contains a DockAreaPane, which contains a DockableControlPane, and I need to customize a DockAreaPane's layout with the following:
- limit its width to a fixed width, smaller than the container's width
- align the tabs to the right (the DockAreaPane has DockedLocation.DockedBottom)
Is there a way to do these?
Bogdan
  • 6158
    Suggested Answer
    Hello Bogdan,
    I believe I answered part of these questions on another thread. The UltraDockManager utilizes standard .NET docking behavior. As such, the docked control will extend the entire width/height of it's container (depending on whether it is docked top/bottom or left/right). There is no way to dock a control to the side of the container but still limit it from extending along the entire side.
    You can change the position of the tabs around the pane by setting the GroupSettings' TabLocation property.
    I hope this helps.
    Chris
