Why is there no AfterCellDeactivate?
Is there a way to get notified if the ActiveCell of an ultragrid has changed to null?
Michael
The Cell is not deactivated when a Column is selected because there is no concept of ActiveColumn, just ActiveRow and ActiveCell. Hence selecting columns doesn’t affect the active cell.
Sincerely,
Sahaja Kokkalagadda
Associate Software Developer, Windows Forms
http://ko.infragistics.com/
The reason bheind this is to disable ribbontool based on if a cell is activated or not.
In the meanwhile I have a workaround, if
a) grid is loosing focus
b) row is selected
Why is the cell not deactivated if I select the column?
The AfterCellActivate is appearantly not fired, if the active cell changed to null.
Hi Michael,
As an alternative you can use AfterCellActivate event. If you can elaborate on this requirement details like why you wanted to know when the ActiveCell is deactivated, and in what scenarios the ActiveCell is set to null, then we can suggest you a more specific solution.
