690
Howto change dropdownwidth in UltraDateTimeEditor showing weeknumbers
I'm using datetimeeditor and changed that to show week numbers with the following code:
        private void udteConfirmedDeliveryDate_AfterDropDown(object sender, EventArgs e) {
            DateTimeEditor editor = (DateTimeEditor)this.udteConfirmedDeliveryDate.Editor;
            PropertyInfo propInfo = editor.GetType().GetProperty("MonthDropDown", BindingFlags.NonPublic | BindingFlags.Instance);
            MonthCalendar calendar = (MonthCalendar)propInfo.GetValue(editor, null);
            calendar.ShowTodayCircle = true;
            calendar.ShowWeekNumbers = true;
But now, the calendar is cut at the right side, and the arrow to "scroll" to the next month is no more visible (datetimeeditor.png)
I tried to set the width in the code above with
calendar.Width = calendar.Width + 100;
but that was ignored.
The ultradatetimeeditor is embedded in a tablelayoutpanel with dock=top. Two columns to the right, there is another datetimeeditor wiithout weeknumbers, displayed as expexted.
How can I change the dropdown calendar width?
  • 690
    Verified Answer
    solution from here:
    http://ko.infragistics.com/community/forums/t/31981.aspx
    calendar.Parent.Bounds = new Rectangle(calendar.Parent.Bounds.X - 9, calendar.Parent.Bounds.Y, 250, 170);
