1833
Poor image quality in published pdf
I'm not expecting much and appreciate that there may well be some conversion anomalies but the current output from the Infragistics document engine is unacceptable. I assume that there's something I've overlooked. I've tried png, gif, jpg and even bmp formats, all are rendered to a less than satisfactory level of quality. I've used FOP in .Net to embed images into a pdf without this kind of drop in quality.
I'm using infragistic v7.2 and the following code...
Dim cellLogo As ITableCell = rowHeader.AddCell()
cellLogo.Alignment.Horizontal = Alignment.Right
Dim imgInnovis As New Infragistics.Documents.Graphics.Image("Innovis_Logo_big.bmp")
Dim image1 As IImage = cellLogo.AddImage(imgInnovis)
One thing to note is that I'm saving the xml, loading it later and then generating the pdf, but I'm sure that this was an issue before also!
Apologies in advance if Mike answers this, I've been asking a few too many questions recently
