Hi, I used Infragistics version 11.2.20112.2112. When I tried to get all no grouped rows in this statement: List<UltraGridRow> rowCollection = this.uxUltraGrid1.Rows.GetAllNonGroupByRows().ToList<UltraGridRow>(); it triggered BeforeRowDeactivate event. Is this a bug or as design? How can I prevent it trigger BeforeRowDeactivate when I just need list of rows?Thanks
I have Visual Studio 2010. I am able to test in my own small project. It looks like something else (Not GetAllNonGroupByRows) triggers BeforeRowDeactivate event. Thanks for help.
You can run the version utility to change the references of the sample to match what you are using or remove the references in the sample and point them to the version you have in order to run it. What version of Visual Studio did you try to open the sample with?
Thanks Mark for your reply. I used different version of infragistics and could not open your sample project. I do need grouping to process the grid. I will try to create sample project and see if there is something else causing this issue. -Clara
I tried this out and the BeforeRowActivateEvent does not fire when I call this code. Nor can I think of any good reason why it should, unless maybe the grid is in a state where the rows collection is dirty and needs to be rebuilt in which case this code, or any code that accesses the rows collection might cause the grid to rebuild the rows and thus change the active row. I suppose this could happen if you are doing some large processing on the grid, or changing the datasource, grouping, or filtering right before this line of code.
I'm attaching my sample here so you can try it out and see if you get the same results. If you are able to reproduce the problem using my sample, then it must be something on your machine - maybe there was some obscure bug in the old version of the controls you are using. In which case, the solution would e to upgrade to the newer version.
If the problem does not occur on your machine using my sample, then something else in your app is affecting this and we would need to narrow down what that is in order to assist you. Maybe you could try either building on my sample or creating a sample from your application until you can reproduce the issue in a small sample we could take a look at.
