Does anyone have any idea what could be causing this issue
The holighted Cell Value should be the "Sum" of the groups "Items" but its total seems to be the same as the Items under Material even though there is no data in that Group for the Price Field
I've also included the code I wrote to calculate the totals for the Price Line. It only appears to happen if the entire gruop has a zero total
If I remove the PartName grouping the issues gets solved.
Inside of ds_AggregateMeasure
if (e.MeasureDescriptor.Name == "Price") { decimal total = 0M; decimal count = 0M; foreach (object o in e.Items) { var item = o as FrBudget; if (item != null) total += item.Price; count += 1M; } e.Value = total; e.Handled = true; }
Hi Jose,
Thank you for your feedback.
I am glad to hear that you have resolved your issue. Please let us know if you have any additional questions.
Hi John,
This did fix the issue, thank you!
Got the email thank you!
Jose,
I have addressed an issue internally, and you should now be able to find the email sent with your private build. Please let me know if this resolves your issue.
I have not gotten the email
Thanks!
