1934
SortComparer does not work after DisplayLayout.LoadFromXML
 OK, so I fire up the grid and bind to my DataTable and I then load a layout from a file.  I know the XML files don't save the SortComparers of the columns so after calling LoadFromXML I set all custom SortComparers again.  It doesn't work though.  I'm trying to sort equities by rating AAA, A+, AA, A+, A-, A, etc.  But even with my SortComparer set after the load I just get A, A-, A+, etc.  It works perfectly fine if I use the SortComparer in the InitializeLayout event, any ideas?
  • 1934
     I should also mention that I debugged line by line and it does indeed go into the SortComparer CompareTo method and nothing else after that.  But once I click the column header to sort again and get inside the BeforeSortChange event then the SortComparer of my column is null.  Like I said, I am not executing any code between those two points and nowhere in my code do I ever set the SortComparer = null.
